September 25, 20215 yr Ok what are you guys thoughts on the 250 Beta rev 3's as im looking for my first trial bike so what are they like overall , thanks 🤔
September 25, 20215 yr Overall they're fine. If you want any specific info you'll need to divulge the year.
September 25, 20215 yr Author 30 minutes ago, motovita said: Overall they're fine. If you want any specific info you'll need to divulge the year. yes i have seen a 2004 for £ 1000
September 26, 20215 yr Author 2 minutes ago, Gary graham said: Need to check for corroded water pump casings... There notorious is the problem easy enough to sort out or is it terminal ? 🤔
September 27, 20215 yr Easy enough to fix. Just more expense really.... Over time, the casing corrodes from the coolant, which ends up in the gearbox.... Had a few revs, found out the hard way when I've drained the oil.... Best to have a look, if it looks milky. Probably needs casing repair
September 27, 20215 yr Author 3 hours ago, Gary graham said: Easy enough to fix. Just more expense really.... Over time, the casing corrodes from the coolant, which ends up in the gearbox.... Had a few revs, found out the hard way when I've drained the oil.... Best to have a look, if it looks milky. Probably needs casing repair ok thanks if i get a rev i will check the oil first thing thanks for the info 👍
October 3, 20215 yr Author so up to now i have sent the guy two messages about the bike but he hasn't bothered to send a reply, it makes me think that if he cant be bothered to answer a simple question is he worth contacting again and does he really want to sell the bike, what are your thoughts guys ?
October 4, 20215 yr 11 hours ago, skyrider said: so up to now i have sent the guy two messages about the bike but he hasn't bothered to send a reply, it makes me think that if he cant be bothered to answer a simple question is he worth contacting again and does he really want to sell the bike, what are your thoughts guys ? Maybe that's not the reason he hasn't replied yet
October 4, 20215 yr Author 13 hours ago, feetupfun said: Maybe that's not the reason he hasn't replied yet so what do you think any ideas 13 hours ago, feetupfun said: Maybe that's not the reason he hasn't replied yet
October 5, 20215 yr 13 hours ago, skyrider said: so what do you think any ideas I have no idea but there are lots of possibilities apart from him not bothering
October 5, 20215 yr Author 4 hours ago, feetupfun said: I have no idea but there are lots of possibilities apart from him not bothering yes perhaps he has had problems at home and he could still get in touch
October 11, 20214 yr Author so i have since looked on the site it was advertised on and it said no longer available (sold in other words ) and the guy never did get back to me, a pity really it was a clean looking bike so anyway i will keep looking
