October 4, 20215 yr Can someone please explain or upload a photo of the return spring on the rear brake of the early 70's Cota 247? I can't understand how the spring attach to the brake arm from the parts manual. Thanks.
October 5, 20215 yr 12 hours ago, Niro said: Can someone please explain or upload a photo of the return spring on the rear brake of the early 70's Cota 247? I can't understand how the spring attach to the brake arm from the parts manual. Thanks. There's a photo showing the spring fitment on this expired ebay listing. Photo found in about 10 seconds using google search. After you open this link, click on "see original listing" for a big photo of it https://www.ebay.com/itm/Montesa-Enduro-125-H-Cota-247-Rear-Brake-Plate-p-n-3855-148-NOS-58M-1977-1978-/293384263589 Edited October 5, 20215 yr by feetupfun
October 5, 20215 yr Author Thanks. How much is crucial to have the small hole in the brake cover? Main is missing the hole. Should I drill one or use without it? Edit: After a close look, I see that the spring attached to the cover only via the hole. I guess I should drill one. Edited October 5, 20215 yr by Niro
