Fork oil question
rrefugee
I have a 2015 Scorpa twenty 300 that has started leaking at the fork seal. No biggie, they are probably the seals installed at the factory. What weight of fork oil should I use and how much oil goes in each leg?
here is a good site about the weights &  viscosity indexes of assorted brands of suspension fluids. www.peterverdone.com..  myself, in forks its motorex. in showa shocks, its Silkoline Pro RSF 2.5 wt. I change these fluids often.
