March 17, 20224 yr Can anyone tell me if these are the same, I thought the way the brake plates were held in place was different for a start and I would have thought some dimensions between the two would differ also. Thanks.
March 17, 20224 yr Both 240 & 300 Swingarms & frames are completely different. Having said that, the alloy swingarms from later models can be made to fit, but not a job for beginners, as a fair amount of engineering required, i.e dural parts to machine on lathe, & lots of alloy welding required. Got a 240 with a 245 alloy swingarm. Have also seen a 300 with a 245 swingarm fitted. 240 / 300 foot peg lowering / relocation is a good mod. 240 fork angle mod also worth doing, as is beefing up headstock area plating, as its prone to flexing. 300 fork angle is pretty good as standard.
