joekarter Posted August 5, 2022 Share Posted August 5, 2022 Looking for one, anyone got one sitting on the shelf? Quote Link to comment Share on other sites More sharing options...
Glayne Posted August 6, 2022 Share Posted August 6, 2022 Nope, wanted one when I first got my 280 Raga, ended up just getting used to it and I'm glad I did. What benefits would you want from one? Quote Link to comment Share on other sites More sharing options...
joekarter Posted August 7, 2022 Author Share Posted August 7, 2022 (edited) Just for smoothing out the bottom. Many of our trials and my practice spot are round river rock. Anything that helps smooth out the power pulses is a good thing. Edited August 8, 2022 by joekarter 1 Quote Link to comment Share on other sites More sharing options...
fourex Posted August 7, 2022 Share Posted August 7, 2022 What about a flywheel weight, I think this one is good for your 2020, says >2013. I put one on my '14 300, made a difference to my liking, additionally I use the map switch to dull things down more when things get extra slippery. https://www.thehellteam.com/flywheel-weight-kit-hidria-s3-gas-gas-2013-ext-fix.html 1 Quote Link to comment Share on other sites More sharing options...
Glayne Posted August 7, 2022 Share Posted August 7, 2022 10 hours ago, joekarter said: Just for smoothing out the bottom. Many of our trials and my practice spot are found river rock. Anything that helps smooth out the power pulses is a good thing. Guess a head insert or flywheel weight may help, of the two I would choose a bit of flywheel weight? I just wouldn't want to lose its snappy power when you need it. I agree with fourex, the map switch can certainly help dull but I find most of the dull to be in the high RPM's. I find the clutch slip to be the best for smoothening the power pulses. Quote Link to comment Share on other sites More sharing options...
joekarter Posted August 8, 2022 Author Share Posted August 8, 2022 13 hours ago, fourex said: What about a flywheel weight, I think this one is good for your 2020, says >2013. I put one on my '14 300, made a difference to my liking, additionally I use the map switch to dull things down more when things get extra slippery. https://www.thehellteam.com/flywheel-weight-kit-hidria-s3-gas-gas-2013-ext-fix.html I've got one installed and changed the gearing. Very much nicer than stock and far easier to ride. Quote Link to comment Share on other sites More sharing options...
joekarter Posted August 8, 2022 Author Share Posted August 8, 2022 9 hours ago, Glayne said: Guess a head insert or flywheel weight may help, of the two I would choose a bit of flywheel weight? I just wouldn't want to lose its snappy power when you need it. I agree with fourex, the map switch can certainly help dull but I find most of the dull to be in the high RPM's. I find the clutch slip to be the best for smoothening the power pulses. That's what I've noticed with the map switch as well. Something to keep in mind on long climbs. So far I like the extra bit of rev that it has over my Beta so that a turn in the middle of a slippery uphill isn't quite as dramatic. Quote Link to comment Share on other sites More sharing options...
kasper Posted August 23, 2022 Share Posted August 23, 2022 I have 2014 280 raga with flywheel weight. Few things I have noticed that made a difference for me: The throttle is smoother Does not stall as easy as it used to stall Carries more momentum Starts easier As you said for "Just for smoothing out the bottom" - flywheel weight does exactly this. The biggest downside, is that it keeps the revs up for a bit and I was gaining speed with "second throttle", when I didn't need it. Not a big thing, but with more tech stuff I tend to forget it and mess up from time to time. Quote Link to comment Share on other sites More sharing options...
