Mwl Posted August 26, 2022 Report Share Posted August 26, 2022 Got a rev 3 125 and evo 250, 09 imaculate and 2010 well used, both bikes I put a new uprated water impeller on. And changed waterpump seal, (the right way around,) Now both bikes got water in the oil, I obviously disturbed something, So I'm going to put a small amount of sealant around the seals, Surely the water pump shaft doesn't wear that much ???? Quote Link to comment Share on other sites More sharing options...
robido Posted August 27, 2022 Report Share Posted August 27, 2022 New shaft Quote Link to comment Share on other sites More sharing options...
TMofCumbria Posted August 27, 2022 Report Share Posted August 27, 2022 (edited) Maybe cut sealing lip as you put shaft through then. Could be a groove i shaft due to previous seal wear or a bit of corrosion on shaft if new seal is contacting it in a slightly different place. Edited August 27, 2022 by TMofCumbria Quote Link to comment Share on other sites More sharing options...
Mwl Posted September 1, 2022 Author Report Share Posted September 1, 2022 Did buy a new shaft, will fit it on one of them, Got two spare seals so will try again, very carefully,lol Thinking maybe I should have greased the shaft before sliding on seal, Quote Link to comment Share on other sites More sharing options...
Mwl Posted October 29, 2022 Author Report Share Posted October 29, 2022 Sorted seals, I must have slightly twisted one, greased it then slid it home, it's now good, Quote Link to comment Share on other sites More sharing options...
