September 12, 20223 yr Can anyone advise if the longer fork tube for the TR80 will fit the MAR legs please, and also are the fork caps the same thread? (think the TR80 caps are different) Wanting to use on a Triumph project. Thanks
September 13, 20223 yr Seeing as the MAR forks are Betor and I`m assuming the TR80 ones are also Betor they should be the same thread. The longer legs will fit. Just be careful with which damper rods you use. I don`t know if the later model ones had more travel in them.
