Scooby147 Posted October 26, 2022 Share Posted October 26, 2022 Got a 2020 one r. Had the front break in bits to stop it sticking. But now the lever comes all the way back to the bar and hardly works. Obviously I have got something wrong but don't know what any advice would be much appreciated Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 27, 2022 Share Posted October 27, 2022 You took it apart. Did you install a new rebuild kit? Quote Link to comment Share on other sites More sharing options...
Scooby147 Posted October 27, 2022 Author Share Posted October 27, 2022 18 hours ago, lineaway said: You took it apart. Did you install a new rebuild kit? No just cleaned everything up. Got it back together but now it hardly works. Not sure if i haven't bleed it up right or i have got something else wrong Quote Link to comment Share on other sites More sharing options...
feetupsbetter Posted October 27, 2022 Share Posted October 27, 2022 You’ve probably just got air in the system & it needs bleeding. Trials bike brakes, (particularly rears) are notorious for being a pain to bleed properly. Make sure you have free play at the lever so to be sure that the master cylinder piston is returning fully after each lever stroke. Some folks say it’s a good idea to hang the whole assembly upside down (calliper at the top) overnight in a warm place to encourage any air to rise up so you can then bleed it to release it, others say they always reverse bleed using a large syringe of fluid onto the bleed nipple & forcing fluid backwards through the line to expel the air. Whichever way, it seems sometimes it’s straightforward and other times it takes loads of attempts. Frustrating but just keep trying. Agree with lineaway though, if I’d got a problem & was stripping the system down, I’d use a rebuild kit at reassembly just to be sure as much as possible is definitely serviceable. Plus, whatever you may have used in cleaning might have an effect on the seal material which could shorten their life anyway. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 27, 2022 Share Posted October 27, 2022 (edited) Another thing, you say it was sticking. The brakes were locking up, the lever was not returning? You used dot 4 brake fluid? Over tightening the adjustment can leave no free play which causes chaos. Also it is possible the bike came with a poor m/c in the first place. Ps, the front brake should just self bleed. Another thing you can try is pump up the lever and tie it closed to the lever over night. Edited October 27, 2022 by lineaway Quote Link to comment Share on other sites More sharing options...
