Bielle
quiq
For anyone who doesn't speak french:
56 minutes ago, quiq said:
Hello, how can I tell if the conrod of a 2012 TXT 300 is screwed up?
Thanks
Le moteur est-il encore en un seul morceau ou as-tu démonté le cylindre ?
Si c'était moi, je retirerais simplement la tête et vérifierais les roulements de bielle, ils ne seront pas bons si c'est tordu !
(Is the engine still in once piece, or have you taken the cylinder off?  If it were me I'd just remove the head and check the conrod bearings, they won't be good if it's bent!)
