Planning on my next project.
LaVern
Let's try this again. Well I must be doing something wrong. It says max size 5.12KB. I don't think I can get it that small. I must be doing something wrong, I've resized it down to 30% of the original size , two times and the smallest one is still 72.8KB.  Okay, I give up, I got to sleep on this one for a while.
LaVern
One more time. This is my bike after the new top end and new front fender. I am still having a hard time getting my pictures to resize to a allowable size. I'm running Windows 11 and it's not like 10.
LaVern
I think I figured out my problem. I was not a paid subscriber. I am now. Maybe I can post some pictures. The first one is what it looks like today with the new fender  and after the new top end. The second one with the high mounted front fender is from 5 or 6 years ago. I can't remember exactly but I did recondition a 1975  Honda TL25o, and last year I did my son's 1978Yamaha TY250. On the Yamaha I was having problems with bleed through on the gas tank son my son took it to one of his friends who does painting on bikes. On the Honda I didn't do it justice by putty knobby tires instead of trials . IMG_20210829_172708316_HDR.thumb.jpg.14217662ad0f2a091a1887e37b6d5fd7.jpg1823871041_Re-workedseatrightside.jpg.7857179ee9242fbaf66a707cd8ac6025.jpg  LaVern
1090066958_75SuzukiRL2504_28_25A.jpg.86e013d62aa68862d0d0974434148b54.jpg2080951756_75RL2502.thumb.JPG.1f7230ebca76ddb31bd2ea94840d368d.JPG
On 9/28/2023 at 2:21 PM, LaVern said:
I don't know if they changed the RL250 engine that much when Beamish built them.
LaVern
Beamish never built the motors. Suzuki did them all.
On the later black engine Beamish , Beamish had some work done on the top end to convert the 325 to 250.
Edited by shakennstirred
I stand corrected then. I thought that the Beamish was the one who changed the clutch linkage  to make it an easier pull, as well as later converting the 250 to 325 not 325 to 250.  I believe they also changed something on the frame, but I could be wrong on that also. Thanks.
LaVern
LaVern
www.beamishownersclub.com  History  will give you the most of the story. Regards Alan.
Edited by Tr1AL
  • 1 month later...
LaVern
The 250 motor in your bike , is a modded Ts250 engine. in the Beamish world, there called the silver engine.
the 325cc engine is a new engine and only came from Suzuki as a 325. Beamish in the UK got some engines converted down the 250cc(because the 325 can be a bit of a handful) these engines are called the Black engine bikes.
Also an interesting note, Suzuki never used the engine themselves, it was a UK Beamish Suzuki exclusive.
ShakennStirred, Thanks for that info. The one thing on my RL250 is the terribly hard clutch pull.  I read, saw, or was told somewhere that Beamish took care of that problem by a totally different clutch activation to ease that problem.  I think and correct me if I am wrong  that is where the cable attaches to a lever on the topside which then activates the push rod. If that is so, did that style originate on a Suzuki engine or was that Beamish design?
LaVern
LaVern
Not on your engine. its was always the worm drive as on the TS250. in the newer black engine bikes the clutch arm was moved to the right-side of the engine . works in the same way as the older TM mx bikes.
You can upgrade the TS based engine like your. to a Clutch case of the TM250. rare to find these days. but they do turn up.
It then will look like the picture ive added to this post
Wow that's interesting. Do you know how they handle the existing clutch rods going to the stator side of the engine?  I also thought I saw a Suzuki, or Beamish or Suzuki/Beamish with a clutch arm coming out of the top of the stator side case. With that it seems easier to do than switching completely to the other side of the engine. Boy, at 73 I'm still learning, and at 73, that's a project that will be left just to think about😄. Thanks for the information.
LaVern
LaVern
Not a mod i have seen. definitely not a Suzuki or Beamish mod
I just spent quite a bit of time looking thru the OEM parts, of Partzilla and Babbitt's and find no parts fiche that shows a TM250 with a right side clutch lever as you show. I can see in your picture it's a Suzuki side cover. I wonder if like Yamahas the Suzukis were manufactured with differences  depending on where they were shipped to. I'm in the USA, where are you located? Thanks for this conversation. I am finding it quite interesting and educational.
LaVern
LaVern
1974 Tm250large.4bfa0b2e6aa99afe62c15cce660959e7.jpg.096d7b8bdfc03f7c824190e2fea6dfec.jpg
I just went to , https://www.suzukipartshouse.com/oemparts/a/suz/50d392fdf8700229982f2f3f/crankcase-cover, It appears to show two different left side crankcase cover, both listed under TM250. It also states, "Diagrams Shown are for U.S. models".   So that explains it a little bit. So  there were  definitely two different styles  made. Same year?  Mid year change? I don't know.  Thanks.
LaVern
