Robzx9r Posted January 1, 2024 Share Posted January 1, 2024 Evening all i am setting up a evo80 big wheel for my son and having trouble finding wheel bearings and swing arm bearings. All the ads are for 09 onwards for the evo. Has anyone else had this problem Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted January 1, 2024 Share Posted January 1, 2024 (edited) 46 minutes ago, Robzx9r said: Evening all i am setting up a evo80 big wheel for my son and having trouble finding wheel bearings and swing arm bearings. All the ads are for 09 onwards for the evo. Has anyone else had this problem Hello, bearings usually have the size code stamped or lazer etched into the outer edge unless they are super cheapo ones. If you remove them you can check them to see if they have any on them. Edited January 1, 2024 by Tr1AL Quote Link to comment Share on other sites More sharing options...
lemur Posted January 1, 2024 Share Posted January 1, 2024 To determine the bearing size measure the bearing in mm and select the correct type; deep grove roller bearing for wheels or needle bearing for swing arm or taper bearing for steering head. Walk into your most local bearing supply store or farm tractor type dealer with an old bearing and it is rarely a problem to source one. Very few motorcycles use something really special in the chassis. 1 Quote Link to comment Share on other sites More sharing options...
