betaflaxton Posted October 19, 2024 Share Posted October 19, 2024 Hello to all ,,a newbie to suspension setup Need some basic advice for suspension setup ,,from the shop front fork damping was fully wound out 32 clicks ,i wound all the way in then backed it out 10 clicks as a starting point ,opinions about this Front preload ,was all the way out ,wound it 7 full turns in then backed out 3 full turns, And havent touched the rear yet but what would be a good starting point Would appreciate any advice ,regards steve Quote Link to comment Share on other sites More sharing options...
totty79 Posted October 19, 2024 Share Posted October 19, 2024 For preload lookup how to set sag. For the damping is largely personal preference, and it's hard to suggest a number of clicks as a starting point especially since the forks might not even have the standard grade of oil in them. I'd suggest trying it fully out, fully in, and half way to get a feel for it then adjust from there. 1 Quote Link to comment Share on other sites More sharing options...
brianrch Posted October 25, 2024 Share Posted October 25, 2024 https://betausa.com/support/ Has everything you need, manuals, suspension supplements Quote Link to comment Share on other sites More sharing options...
betaflaxton Posted October 25, 2024 Author Share Posted October 25, 2024 Thanks for the info , what's really needed is how many turns to set the rear shock to standard setting on preload , also it states that you can have up to 10 turns for front fork preload in the manual but it is only possible to get 7 full turns Quote Link to comment Share on other sites More sharing options...
totty79 Posted October 25, 2024 Share Posted October 25, 2024 I doubt there's a standard preload but even if there is you don't want it, you want the right amount of sag. Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted October 26, 2024 Share Posted October 26, 2024 On 10/25/2024 at 3:41 AM, betaflaxton said: Thanks for the info , what's really needed is how many turns to set the rear shock to standard setting on preload , also it states that you can have up to 10 turns for front fork preload in the manual but it is only possible to get 7 full turns What year is your BETA EVO. Quote Link to comment Share on other sites More sharing options...
