Rejet Carburetor on a 300 R
Assgas
2 hours ago, Assgas said:
I would like to change needle  on my 21 300 R   It seems to be lean 1/4 to 1/2  throttle
any recommended  jetting and needles
It would be great if jetting were that simple as in reality there are many variables that need to be considered  , this is why some people rave on about Efi  but that has its own problems at times. To start with have you lifted the needle by lowering the clip into the slot down from  where it was when you found it lean and tested that.
Edited by Tr1AL
Well you are correct on that stock it is lean. All the bikes stock come lean from the factory. The Gas Gas forum had a lot of that info. It all depends where you are from as the fuels can be different. Seems in the .U.K. they were big on changing the slides on the pwk. But I think they also showed a different needle. In the states we usually just increase the pilot size, but our fuel is different and we ride higher elevations.
 Hopefully someone replies with a thought on the needle.
21 hours ago, Assgas said:
Yes I know about how to jet.
What I really asking is there a needle that works better than the standard one. Some riders really like .
Sorry I did not understand that . Please forgive me. Best wishes Alan.
On 11/24/2024 at 10:27 PM, Tr1AL said:
if you know how to jet why are you asking what clip position . How are your brakes did the slots cut into the pads make your brakes not work properly.
Im old and lazy I just like other opinions from people .  Brakes don't lock up with the slightest touch anymore.
  • 3 months later...
The design of that  carb is very interesting I like it a lot but at $700.00 USA and £770.00 in the UK it seems to be a works rider only choice. At club level in the UK it seems a little excessive to my mind . A couple of years ago I bought a second hand genuine KEIHIN PWK28  with standard manufacturer recommended jets/settings  for £50.00 off ebay gave it a clean by hand and it worked absolutely crisp from pick up through to rev out. If you have Elons money then of course why not if it works as well as they say its like having fuel injection as you point out. Enjoy and no more jetting problems for you , that has to feel good. All the best Alan.
