June 17, 20251 yr I just picked up a 93 Aprillia Climber last night. It’s in good original condition. Just needs some maintenance. It came with a lot of new and extra parts. I need to weld the tab for the rear fender mount. I noticed the swingarm is a little loose. Anyone know the bearing sizes or if there is a bearing, sleeve and seal kit for the swingarm? Edited June 17, 20251 yr by dozerash
June 23, 20251 yr Author Anyone have a parts manual to the 92,93,94 Climbers? I have the 89 manual but there is some differences. Thanks Edited June 23, 20251 yr by dozerash
August 25, 20251 yr Author I have my 93 Climber running! It started on the second kick! Ran good, a little rich. Clutch was stuck, typical Rotax, I fixed that on my SWM with new fiber plates. Took awhile but it finally freed up. The clutch felt either on or off so new plates should help. Gearing felt fine, power was good, lots of compression! It needs to be jetted better or another carburetor ( I have had great luck with OKO on my SWM)!
October 30, 20251 yr Author Took the Climber to our vintage trials last weekend. Worked great 👍 Fun bike!
January 19Jan 19 Author On 10/30/2025 at 7:22 PM, nhuskys said: Are we going to get an early water cooled class in EVT? Yes, Chris said he might start a new class this year. Otherwise the early liquid cooled bikes are legal in the modern vintage class.
January 24Jan 24 Author My Climbers rear shock stop bumper has disintegrated. Where can I find another one? The shock shaft is 14mm. Thanks
