DanRev4t Posted June 18, 2025 Report Share Posted June 18, 2025 Hi All, My 2008 Rev 4t needs a new water pump impeller as the plastic one has cracked and the bike is running very hot. My question is, I have seen the Apico/Jitsie upgrades for the Rev3, is anything similar available for the Rev4t? Just a suggestion for a metal impeller that fits would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted June 18, 2025 Report Share Posted June 18, 2025 @DanRev4t The 2007/2008 Rev 4t uses the same water pump components as the 2009 on BETA EVO 4T , as far as I know the APICO BETA aluminium upgrade parts are listed as a fit on a 4T BETA motor water pump ? Check with BETA in ITALY to see if the parts are the same. If you don't want to chance it. Quote Link to comment Share on other sites More sharing options...
reggie Posted June 21, 2025 Report Share Posted June 21, 2025 4t impeller is different than the 2t Quote Link to comment Share on other sites More sharing options...
