Exhaust header to mid seal replacement
smarty156
I need to replace the 2 seals between the exhaust header and mid section on my 2024 TXT Pro Racing.
Any advice? Remove header or mid box?
I looked at removing the header pipe but can't see how i can get the lower hex bolt out of the barrel as the exhaust is in the way. A normal Allen key will go on but will only turn a few mm before it hits the exhaust or sump guard/frame.
Any help/tips much appreciated. Thanks.
 Hello cut a bit off the allen key to get in there better and work it slowly then swap it for a normal bolt with two or three washers when you put it back on ...... or use a flexi extension to get on the allen bolt.
  • 2 weeks later...
