Millwoodva Posted August 5, 2025 Report Share Posted August 5, 2025 The needle bearings are exposed on one side only. I did not take note on disassembly. Do the bearings roll on the tappet or the backing plate... Thank you in advance.. Jeff Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 5, 2025 Report Share Posted August 5, 2025 Search on you tube for jim snell video's. He makes one for the clutch only. For 1995 thru 2001 models. You should be able to see what you are looking for. Quote Link to comment Share on other sites More sharing options...
Millwoodva Posted August 5, 2025 Author Report Share Posted August 5, 2025 (edited) Thank you.. I had watched it previously and it's a bit too grainy to see which way the bearing is facing. I spoke to his partner Jesse and we came to the conclusion that the metal side goes against the backing plate. Edited August 5, 2025 by Millwoodva Quote Link to comment Share on other sites More sharing options...
