NobbyC Posted August 10, 2025 Share Posted August 10, 2025 Hi team, Had an issue with my TY, engine ran away due to leaking crank seals, totally leaned the poor thing out and had to stall it to stop the engine. Replaced seals and upon re start very noisey, struggling to idle and noticing movement in the head and barrel so presumIng I have stripped the head studs. Has anyone else experienced this? Cheers Rob. Quote Link to comment Share on other sites More sharing options...
lemur Posted August 10, 2025 Share Posted August 10, 2025 Sadly yes, nothing that a new engine didn't fix. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 12, 2025 Share Posted August 12, 2025 On 8/10/2025 at 5:02 PM, NobbyC said: Hi team, Had an issue with my TY, engine ran away due to leaking crank seals, totally leaned the poor thing out and had to stall it to stop the engine. Replaced seals and upon re start very noisey, struggling to idle and noticing movement in the head and barrel so presumIng I have stripped the head studs. Has anyone else experienced this? Cheers Rob. Maybe the cylinder studs or their aluminium nuts have stripped but that is unlikely. Maybe you have lost some of the cylinder base gasket. Maybe a leaking cylinder base gasket caused the initial runaway. Stripped head studs will not cause the barrel to move because the barrel is held in place by 4 (cylinder) studs at the bottom. I'm interested to hear what happened once you work it out. 1 Quote Link to comment Share on other sites More sharing options...
NobbyC Posted September 10, 2025 Author Share Posted September 10, 2025 Hi again, after stripping head and barrel I discovered back two barrel bolts were able to be loosened by hand and a very thin and compromised base gasket. Manufactured a nice thicker new gasket, reassembled and torqued everything to spec and started 2nd kick and after warm up idled nicely, Hopefully bullet dodged. Cheers Rob. 2 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted September 10, 2025 Share Posted September 10, 2025 Good outcome. I suggest you re-torque the cylinder hold-down nuts after a couple of heat cycles. There's a good chance of generating another base gasket leak unless this is done. Quote Link to comment Share on other sites More sharing options...
