bikeskint Posted 12 hours ago Report Share Posted 12 hours ago Hi again.. I've not started the bike for a couple of days and now the kickstart is not moving.. I can literally stand on it And no movement..if I pull the clutch it goes full stroke.. also if I remove the plug so no compression And put it in second I can crank the bike forward on the kickstart.. any ideas please on what is going on? Stuck or damaged gearing Quote Link to comment Share on other sites More sharing options...
b40rt Posted 10 hours ago Report Share Posted 10 hours ago Not specific to ossa, but the kickstart gears can get out of alignment. Sometimes just putting it in gear and rocking it back of forward is sufficient let them mesh. 1 Quote Link to comment Share on other sites More sharing options...
bikeskint Posted 9 hours ago Author Report Share Posted 9 hours ago 1 hour ago, b40rt said: Not specific to ossa, but the kickstart gears can get out of alignment. Sometimes just putting it in gear and rocking it back of forward is sufficient let them mesh. Have tried the obvious (rocking etc) but thanks Will try a tow start later and see if it re syncs with the engine running.. if not it's off with the clutch case I guess 🤦♂️ 1 Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted 9 hours ago Report Share Posted 9 hours ago (edited) 21 minutes ago, bikeskint said: Have tried the obvious (rocking etc) but thanks Will try a tow start later and see if it re syncs with the engine running.. if not it's off with the clutch case I guess 🤦♂️ The Gearbox needs to be in neutral or have the clutch lever pulled in to start the bike , have you assembled the kick start shaft/gear and the parts correctly is it inserted fully into the engine casing before replacing the clutch casing .Check your work again following the service manual. Regards Alan. Edited 8 hours ago by Tr1AL Quote Link to comment Share on other sites More sharing options...
bikeskint Posted 7 hours ago Author Report Share Posted 7 hours ago Hi Alan I've only had the bike a few days so haven't actually done anything to it, when I collected it it kicked over fine.. IN neutral it's solid and no movement..with the clutch IN there is kickstart stroke but no engagement? Quote Link to comment Share on other sites More sharing options...
