burns1989 Posted January 31 Report Share Posted January 31 Hi all where can I get the difrent sized shims for the clutch adjustment as my clutch slips badly when the clutch gets hot. Thought I was wheel spinning antill my m8 said its not spinning the wheel. Quote Link to comment Share on other sites More sharing options...
dan williams Posted February 1 Report Share Posted February 1 (edited) Receipt 40105424.PDF https://www.mcmaster.com/products/91437a555/id~16-mm/thickness~0-005/ https://www.mcmaster.com/products/91437a555/id~16-mm/thickness~0-005/thickness~0-01/ Edited February 2 by dan williams Quote Link to comment Share on other sites More sharing options...
burns1989 Posted 1 hour ago Author Report Share Posted 1 hour ago On 2/1/2026 at 8:20 PM, dan williams said: Receipt 40105424.PDF 200.77 kB · 56 downloads https://www.mcmaster.com/products/91437a555/id~16-mm/thickness~0-005/ https://www.mcmaster.com/products/91437a555/id~16-mm/thickness~0-005/thickness~0-01/ Thanks, found out the rev 3 shouldn't have a shim at all exept the bearing washer Quote Link to comment Share on other sites More sharing options...
