simon0116 Posted 4 hours ago Report Share Posted 4 hours ago Fitted a electronic ignition as instructuons say. Now ty will only start by putting a drip of petrol down bore. Good spark, new petrol, clean carb, reeds look ok. Timing is 2-3mm measured with strobe. Once running rev/ rides fine. Kicks back up ok. Only tried it for 10mins running Any ideas before i put old ignition on to prove a point, or is 200 majesty timed diffent to a ty175 Thanks Quote Link to comment Share on other sites More sharing options...
feetupfun Posted 1 hour ago Report Share Posted 1 hour ago It should start easily at 2-3mm BTDC. Did you do anything else at the same time as fitting the new ignition? Quote Link to comment Share on other sites More sharing options...
