beta-boy Posted June 4, 2006 Share Posted June 4, 2006 well when i was working on my bike i guess there was still some oil in the transmission cause i was working on the clutch and had the bike tipped on its side a bit for a better angle, well i guess i didn't get all the oil out and i noticed when filling the oil that it felt like there was too much in there what should i do drain and re-fill with the correct amount drain a bit and risk having not enough or will it just come out of the vent thanks -Jesse Quote Link to comment Share on other sites More sharing options...
andy_290 Posted June 4, 2006 Share Posted June 4, 2006 Re-drain and fill with the correct amount mate! Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 4, 2006 Share Posted June 4, 2006 If you are ever unsure, drain and refill. Level too high or too low in service is bad news. Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted June 4, 2006 Share Posted June 4, 2006 You know you say you tipped it on its side was that to get the oil out ? Because i know most gassers or even all of them have a drain hole/plug under the sump/bash plate have a look and drain it out fully that way first. Then fill it up from the top or side. What bike is it by the way, year ? Quote Link to comment Share on other sites More sharing options...
beta-boy Posted June 4, 2006 Author Share Posted June 4, 2006 yeah after i read it, it didn't make sense either, the bike wasn't warmed up first,and i realised there was still some in there when i went to fill it ohwell i warmed it up drained it and re-filled it before my ride, so its all good Quote Link to comment Share on other sites More sharing options...
