Trials Central: Poor Running 305 ? - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Poor Running 305 ? Help!! Rate Topic: -----
#1 User is offline   wookey
  • New Member
  • Pip
  • Group: Members
  • Bike:fantic 305 ??
Posted 06 February 2010 - 03:05 PM
HELP! I i've just bought, what I think is a 305, but really not sure and don't know how to tell.
The problem is that it starts on choke but the runs erratically, revs quite high and then cuts out unless I can give it a bit of choke. I't's been stood a few years. Can anyone help? Does anyone know how many 'turns out' the slow running screw should be? Any ideas??
Wookey
#2 User is offline   bambam_n_chunx
  • Member
  • PipPip
  • Group: Members
  • Bike:240&303 fantic
  • Club:darlington/castleside
Posted 06 February 2010 - 03:32 PM
Have you given the carb a good clean out. With it being stood a while the chances are the pilot jet has been blocked up by the fuel going off.
This a common problem and once cleaned out the bike should run somewhere near. Screw should be around 2 turns out.
Good luck.
#3 User is offline   wookey
  • New Member
  • Pip
  • Group: Members
Posted 06 February 2010 - 04:35 PM
Mmm, thanks, I'll try that. Any idea what grade plug it should have?
#4 User is offline   DMCK_FANTIC
  • New Member
  • Pip
  • Group: Members
  • Bike:Fantic 305&Section
Posted 06 February 2010 - 05:02 PM
Save or print these, 305 info sheets, http://s292.photobucket.com/albums/mm22/fa...c5seriesmanual/ I have my air screw out at 1.5 turns on my 305.
#5 User is offline   wookey
  • New Member
  • Pip
  • Group: Members
Posted 06 February 2010 - 05:32 PM
Brill, got that. Will print them off. Forum is excellent, wouldn't know where to start otherwise
#6 User is offline   NZRalphy
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:Beta Rev4T
Posted 06 February 2010 - 06:16 PM
Also check that the inlet manifold is not cracked or perished - it can give similar faults
I'm not half as good as I think I though I was...
#7 User is offline   gtgasgas
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:04' RAGA #224
Posted 08 March 2010 - 11:42 PM
Carb is clogged the only reason it runs on choke is that its letting fuel in to the carb. Clean the carb and change fuel line, I had black hose do that exact thing on a 305.
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
