evo leaky petcock
twinkletoes
Hi guys
as the title suggests the fuel tap has a leak on my 2010 evo. a slow drip. it cannot be tightened up anymore without the on/off/res tap turning behind the cdi box.
the frame is regular threaded and the petcock left threaded to bring them together and create the seal. it could do with some sort of fibre washer in there perhaps, between the bottom of the plastic fuel pipe that enters the tank and the tank threads itself.
anybody else sorted a one of these before and how? i cant see a new one fixing it
cheers
Plumbers Tape For Everything
might have guessed. I ll try that. If not its a new one,cant see why the old one would sstart to leak after this time mind you.
only traced the leak back after thinkig i had oil on the garage for, turned out to be 2t oil with fuel evapourated off!
what will be next months stupid little issue i wonder....
thanks
