Hot Start Mod essential
#1
Posted 04 August 2005 - 07:04 PM
RE500s hot start mod on the sherco 320 4t has absolutly transformed the
hot start issues with my bike
for no apparent reason my bike would refuse to start ,sometimes taking 20+ kicks
now i still try and start as normal but you can tell if it is having a funny 5 mins
lift the hot start open the throttle a little and one kick to clear next kick starts
i have even turned it upside down when really hot let the motor stall and it still starts
if you have not done it do it NOW
#2
Posted 04 August 2005 - 07:39 PM
Oh and by the way, I wouldnt recommend anyone buying an 05 model of this bike until this problem is sorted.. I even heard that the 4T at Hawkstone had problems starting
Groucho Marx
#3
Posted 04 August 2005 - 07:59 PM
mine never needed choke even when really cold,i posted the question ages ago.
It seems they are all a bit different,i just kick it a few times and it is away,
But when hot it was without reason,one day good one day bad.
have you tried not using choke? does it flood when cold (mine did every time with the choke on)
After doing the mod (20 mins max) it has made me love it again.
Its still to pokey though,but i no longer want to burn it.
#4
Posted 04 August 2005 - 08:41 PM
Also, the venue is quite big so when i got it going, after i had been riding it a while, I gave it a blast in 5th flat out for about 20 secs and oil p****d out the breather and splattered everything. smoke was billowing from it coz it went all over the exhaust. looked like something out of a carry on film!
When riding it I love it to bits.. but these little niggly things are starting to p*** me right off
Groucho Marx
#5
Posted 04 August 2005 - 08:57 PM
did you turn the fuel off before transport,i have had a similar one but only at a practice ground, it had flooded the air box
I think it is a love hate relationship.
another thing i do now is take a spare filter to events . if it dusty even that effects starting.
try taking out the choke jet and blanking the hole it really works
#6
Posted 04 August 2005 - 11:06 PM
The oil out the breather is because there`s too much oil in it. You definately have to remove the 6mm screw under the countershaft sprocket as per the 2T, and an extra couple of hundred mill comes out, even after you`ve taken out the filter, which is right next to it.
This post has been edited by Andy: 06 August 2005 - 10:47 AM
I`m a pupil of experience.
#7
Posted 05 August 2005 - 04:56 AM
#8
Posted 05 August 2005 - 06:49 AM
when the bike is on level ground and been stopped for 10 mins or so, the eye glass is showing the oil at the correct level? Im assuming that because i was riding the bike flat out, the oil was being thrown into the camshaft compartment by the chain at such a rate of knots that it pressurised and came out the breather? No problem when running at low speeds. ?
Groucho Marx
#9
Posted 05 August 2005 - 07:10 AM
Dixie, on Aug 4 2005, 09:57 PM, said:
You are onto something here
thanks for that advice
Groucho Marx
#10
Posted 05 August 2005 - 11:04 AM
I took the bike down to work with the fuel off.. took it off the trailer and started it ok
Well happy.
Thanks again !
Groucho Marx
#11
Posted 05 August 2005 - 01:40 PM
glad it helped,i am really trying to get the four banger sorted and these forums have really helped
Ishy if you read this keep helping and ignore the pilloks
re500 saved me from blowing my 4t up
KEEP UP THE GOOD WORK
I ride bikes every day and have never driven a car and ime over 40
it never ceases to amaze me how bikers try and devide them selfs
if i ride my harley people wave if i ride my scooter i am invisible
I have more respect for the guy that rides his mz to work every day than the weekend 1000 rider but i still wave at them and would stop if they needed help would it go the oyher way,probably not .
#12
Posted 05 August 2005 - 04:34 PM
Sorry guys, but I can't find the hot start mod referred to at the start of this thread where is it?
Cheers...
Big John
PS - remember there has never been a "perfect" trials bike made - ever!
Highland Classic 2 Day Trial (UEM) 9/10 June 2012, Alvie Estate, Aviemore, Scotland..."The Friendliest and Biggest Classic Trial in Scotland" !!
"Just Shut-Up and Ride!"
On any Sunday, I'm a flyin' Man!
and finally...It's just my personal opinion!
#13
Posted 05 August 2005 - 04:38 PM
I noticed when you change the oil 700cc in the main filler and 100cc in the other, it just measures spot on the red line in the sight glass, then when you start it and let it run a while on tick over the level will go down, due to the oil getting up to the top end, stop the motor and it drains down after a minute or two to measure spot on the line again, make sure you check the oil level cold or at least give it a few minutes to drain back down before checking against the level marker.
One of the biggest problems with the bike at the moment is information, and I suspect more of you are having problems with the first batch of bikes than the later production bikes over 00100.
Another thing is what is normal operation for the bike and what isn't, to tell the truth I have not really had any problems.
My advice to anyone getting one new, is don't take the top end off, to check the clearance unless you really know what you are doing, let your dealer do it, in fact make a deal with them to do the initial valve check for free if you buy one, no one seems to have had to adjust the shims after five hours anyway, Howard said he was a thou off on one but that could of even been a thou off to start with.
We are finding it hard to source the correct plug, but a bosch equivalent is on it's way from RYP, I'll post the number when I get it, the correct gapping of plug at 0.6mm is important and does help starting.
Do you have the parts download and service tip download WM, why don't you start a closed topic on the 3.2 and post both on there for quick reference and any other good information that you think would benifit owners could be copied and pasted into the topic by you.
Left, Right, and send it on.
John Isherwood.
#14
Posted 05 August 2005 - 10:48 PM
Had a customers 4t fill the air box aswell ,when fuel was left on. This can only be due to a faulty float needle, which seems to be a random problem on some.or if the overflow tube that links the two drain ports, is above the rubber inlet manifold, or blocked. Noticed Paxau is doing PWK`s. Might be worth a chat.
Ishy, we can get the same range plug here ,but only with the solid tip. So it`s either change the plug cap or machine down the tip and put a 4mm thread on. Did the latter ,while waiting for order from factory.
This post has been edited by Howard Wallace: 05 August 2005 - 11:00 PM
#15
Posted 06 August 2005 - 06:15 AM
So the fix is really to make sure the tap is turned off when transporting it! Seems like good practice anyway
Thanks for your help, well appreciated
In relation to the carb, I noticed the 4T at Hawkstone had a Kehin carb fitted with upgraded needles and jets (the rider told me but didnt say what they were).. But there was a time when he went to start it and couldnt and a few other peeps had a go and couldnt either
Groucho Marx
Help
