gerko
28 -
Hi guys does anybody know the replacement part number for the Spherical bearing that fits into the shock absorber. id 12mm od 26mm x 12mm width. Finding one is proving difficult .
As you say there is a massive difference in newer bikes, mine compared to my mate 93 model and other mates beta is massive, miles lighter and better balanced. Ive not rode a twin shock since my teenage years, but i like modern bikes anyway. Get a ride on one im sure you wont look back
Cheers mate , ive managed to replace all the roller bearing in the linkage at less than half the price that robbers Beta wanted . I'm struggling my a*** of to find a replacement spherical bush for the bottom of the shock though. beta £40 jokers
sight glass is on the left hand side if your sat on the bike , at the bottom of the engine near the frame, similar size to 50P. looks like a big nut if its clouded up or full of gunk buy a new one. tap it with a metal object if it sounds plastic then you have the right bit. As for your manual , good luck i've never found one on line , and parts for beta's only seem available from the lampkins uk at ridiculous prices. Just my opinion ,beta is closed shop, you want one then you must buy our parts only. so glad i own a GAS GAS
Does anybody have the bearing codes for the Needle bearings that fit the bottom suspension bracket. 4 in total , 2 on each side ,upper and lower.??? And the bottom shock spherical bush??? I could phone lampkins i know but they are mega expensive Thanks for any help
Hi guys Im getting extremely frustrated simply trying to find the engine oil spec for a friends 98=99 Lampkin rep 250 Beta. Im sure one you of helpful people can assist me. Beta UK website is absolute garbage. Thanks
while out today i noticed my front disc had cracked, Can anybody tell me the best place to buy a new/replacement one ? cheers
sorry thought i'd put it on its 2005 Raga model
Can anybody provide me with the replacement codes for the front and rear wheel bearings for my TXT pro 300 Manual says Rear C160001 Front ME120136055 Thanks Gents
Cheers guys , awesome advice. I will follow all the above and report back. My first ever trailer so its all a learning curve.
They do look like there a few years old , Should you be able to move them by hand ? they seem solid
Can anybody tell me how to test the suspension on a trailer, independent rubber bush type. My trailer seems to vibrate when driving. Not sure if the need replacing or its just how it is. (ps this is used trailer not managed to test it with my bike on but trials bikes are hardly heavy.
