It's strange, that you say the bike hesitates. Because in a GasGas video the mechanic said, that if the bike hesitates, then it's running too lean and not too rich. Anyway I would say, that it's easier to turn the air screw, and leave the jets as they are. Try what's happening if you turn out a bit (anti-clockwise) the air screw, so you will get a leaner mixture.
Also, it's a good idea to clean the carb, because this can also cause hesitating.
And don't forget, that it is important that how much oil do you add to the petrol. More oil -> leaner mixture, less oil - > richer mixture. Some jets can work good for 50:1 petrol-oil ratio, but they are not working good if you use 80:1 petrol-oil ratio.
My opinion is that this is most probably piston slap. If the carb would make the bike run lean, then it doesn't make any extra noise. If it runs lean, then after 30 mins - 1 hour, the engine will be too hot, and detonation, preignition occurs, which really makes sound, but I don't think that this is the case.
It's a false economy changing the rings and top end bearing. It will make the compression a bit better, but the engine noise will remain.
Some engine noise is normal, but if your's is making really excessive noise, then you should drain the water, and open the engine. The best way is to put the piston Without the rings (!) in the barel, and see if it's loose. The piston has a very bit of play in the barrel (because the piston expands when hot), but the clearance should be less than 0.1 mm. If the clearance is big, say 0.15 mm or more, then your problem is piston slap. You need to buy a new piston. (Of course check the barrel, too, for scores and scratches (which can occur if you have a problem with the air filter), and be sure that the piston is worn, and not the barrel. But anyway it's uncommon that the barrel to be worn.)
The carb leaking is a typical Mikuni carb problem. The solution is the drilling modification. You will find information about this modification in the sticky "New Rev3 Mikuni Carb" topic. It's easy to make the mod, so don't worry.
I think it's not recommended to use fully synthetic oil in the gearbox, because sometimes the clutch will slip. The synthetic oil is very "slippery". I think that a mineral oil would be better.
I'm an absolute beginner. I've set up my suspension (both front and rear) with more spring prelod, and almost zero dampening. I'm a bit heavier that's why I need more spring preload and I set the dampening almost zero, because in this case the motorcycle jumps better. But this setup has drawbacks when it comes to steering and in many other cases, too.
I made the drilling mods, too. The fuel leaking problem solved. But I don't see any differnce about the engine stalling downhill. So, I've set the fuel tangs a bit even higher, and I think that now it's ok. Still not perfect, in some really steep downhills the idle speed still decreases, but most of the time it doesn't stall.
I saw a picture here about a float extension bowl and a main jet shroud. From where can I order theese, and how much do they cost? And are they making the carb absolutely perfect?
All the bikes has an amount of engine sound. (I'm not talking about the sound of the muffler and I'm also not talking about piston knock or something like this.
I'm talking about the normal sound of the engine itself.)
Brand new bikes are pretty silent in the engine area. But with time somehow this sound can increase.
Is it possible the reduce the engine sound? For example a new piston makes the engine more silent? Or new bearings, or what?
I have made the Billy T modifications, so the tang level is correct now. It's way better, but sometimes on decline, the engine still stalls, and the bike can't be started facing downwards.
Should I make the drill modifications? Will that solve the problem? Or the drilling method only solves the fuel leaking problem, and has nothing to do with the engine stalling on decline?
Super good video. It's a must. Footage from Adam Raga (and many other riders, too), huge jumps, trialshows, burnouts, and many others. It's a must see.
ADMIN Content is copyright and therefore illegal to copy and distribute without permission therefore link has been removed
Beta Running Rich
in Beta
