80 -
this may not be the solution, but in the past when i've had this problem i've riden the bike holding the front brake until disk in dam hot then put water onto the caliper, bingo sh*t hot brake. that's my method. hope you sort it out.
I'm moveing over to Derry in the summer and will be looking for any events, clubs or practice areas around there, any info would be greatful.
Thanks for the result I was looking for from you here, this works a treat and if any body would like some i got 49 left to get rid of. Happy Days. just the job,clicky clicky.....
how did you get the old one out, half the nut has broken with me. thanks to you all for the advice.
Right then I'm in a pickle as the nut in the air box that holds the mudgaurd has buggerd up, the nut has only a few threads left and does not take enough of the bolt.What can I do? any ideas welcomed, apart from buy new air box.
Waw! I still got the tears running down my face. Wonder if I keep my scorpa for forty years my young ones will do that up,proberly will be still running.
did you sort brakes out,if it is still a bit spounge try riding the bike holding the front brake till it heats disk up then put water straight onto the disk.the disk should be sizzling, works every time for me.
I put a larger lever res on mine because i was having arm pump when i first had bike, then the other day put smaller one back on and found that it was fine. i reckon it was more to do with clutch adjustment, as i was pulling lever back and it was stopping short of the bars. so when i was in a section and struggerling to hold on the bars and the lever i was pulling on could not physicaly come back to the bar. abjust so theat lever comes back to the bar and you may find it is less tiring. this may help if not try bigger res.each to their own.
Put new one in,that will tell you if the old one is kuput.It's not worth cooking engine.
There's a new viagra eye drops,it does not make you stiff. It just makes you look hard.
Would It Be Good To Do Weights
coldcake replied to sherco25016's topic in Trials Training And Technique
This section is one of the best in the forum for improving your skills. I have been doing yogo for 4 months and have got to say it has helped with me balance, well it has found my weak points.So i can work on them.Don't be fooled,my class is averaged age is 60 and all woman.I train 2-3 times a week and they could jump over my shoulders. My training is 10 mins warm up running,leg press,chest and back.Then triceps and biceps. 4 sets of 10 ish reps with 30-40 seconds rep in between reps and 3 mins between each exercise.the rest period I normaly do incline sit ups. With two days rest . Also big plus for me is protein shake straight after work out. Big thanks to billycriag, always good tips. -
Thanks for replys,thought the title would grab your attention. All drilled out and working fine,was not to sure on taking insert out, are these inserts available off the shelve?
As the title suggest,my scorpa's air box has lost it's thread on one of the brass nuts.So apart from boring out to M6, is there any way of getting the nut out and replacing with new one?
How can I check to see when me subsciption is due?
