Keihin Carb
north_yorkshire_lad
take your throttle spring out of your carb and cut it down two to three turns but do it a little at a time until you are happy but dont go too far otherwise it`ll not spring back, maybe also give all the throttle a really good clean aswell and use only a tiny bit of grease on the bars just enough to give it a thin coat otherwise this will also affect the performance
