October 23, 200620 yr hi all got a problem with my 2000 270 rev 3 its starts and doesnt kick back makes good power and sounds crisp but when it rech,s full operation temp it starts to brake down and wont rev past half throttle and you can here it ping and carry on if i stay below half throttle its fine its just when you crak it open ive cleaned the carby changed the plug cleaned the air cleaner so im thinking its electrical so can it be the coil or mabey the stater any thorts thanks travis
October 23, 200620 yr Sounds silly but check the simple things first . change the plug and disconnect the kill switch these can give these symptoms believe it or not. i doubt it will be the stator these tend to either work or not. Then the coil sounds electrical though!
October 23, 200620 yr If its heat related, its more likely to be the stator than the coil. If its heat related, start at the engine and work your way out from there. This was the case with my daughters 125. When hers got warmed up it had a tendancy to run backwards. I also found a tendancy for water to collect behind the stator cover which may have caused its failure. I think it got in during pressure washing. Now I always remove the cover after washing and let the stator air dry before replacing the cover. Edited October 23, 200620 yr by Pattonfamily
October 23, 200620 yr which reminds me! off out too drill some drainage holes in the bottom of my cover
October 23, 200620 yr Just remembered about the fuel filter too! ordered one and some fuel line today so shall do that this week Has too be said though my bikes gotta be better than it EVER has been mechanicly now, all this boredom and spare time, just end up staring at the bike looking at what could be done too it
October 23, 200620 yr sounds like the stator. but talk to Lampkins, they may send you a stator and a coil and you can return what you dont use. or you could get the stator rewound which is cheaper, look in TMX.
October 27, 200620 yr Author thanks for all your reply,s i felt it mite have been the stater but are un shore of how to test it thanks again travis
October 28, 200620 yr I had the exact same problem for a while. Then one day before an event i went to start the bike and there was no spark at all. First i checked the kill switch and changed the plug. Thought it was the coil then so checked it out. Was getting power to it but none after so i ordered a new one. Tried it and the same problem, Lampkins recommended a CDI unit so i got one and it started first kick and revs out perfect. I'm no expert on electrics but from what you're saying it's the very same problem i had. Cost about Edited October 28, 200620 yr by Dell
October 29, 200620 yr Author lampkins sounds like a good bloke to deal with but im in australia so ive removed the stater coil voltage reg and cdi and will take them in to my local beta deal and have them tested and when i was removing the stater i noticed the timing gap from the edge off the screws and the end of the slot was about 15-17 mm not 2.2mm like stated on the other thread about timing a 270 is it possable its the timing just a thort im still going to have the electrics tested thow travis
