October 29, 200620 yr Help! Ive got a REV 3 250 2000 model and something is certainly not right! I was out last weekend and the bike started ok and ran for say an hour then the bike stalled and could I hell as like start it! So back to the shed and stripped the carb cleaned the jets etc re assemble etc. I have cleaned the air filter and changed the plug to the right gap. The bike trys to turn over but only fires for say five to ten seconds then dies. It may be ive cocked up the carb adjustments as I am pretty new to all this. I have the mixture screw set at two and a half turns. I am trying to set up the carb but cant get the bike started long enough to balance it. After 15 mins of sweat I have put the bike away. Not sure where to go from here! Electrics? or Carburation?
October 29, 200620 yr Author Ok so ive had the spark plug out of the head and cranked it over but no visable spark! any ideas? Coil?
October 29, 200620 yr Hi Chris, Try your Stator plate and the coil as a first step. Did it run "Lumpy" before it stopped, If so it could be the cdi unit.my old man has had similar problems recently. If you're stumped and get no joy on here give Lampkins a ring, either Gary or John are always happy to help Cheers Donald
October 29, 200620 yr Author Thanks slapshot. Yes it definately did run lumpy before it just stalled and died.
October 29, 200620 yr Before you get to the hardcore parts removal check the kill switch. I've seen several problems from Beta's with intermittant shorts. Also make sure nothing is rubbed bare on the wire harness. Hopefully you can get away on the cheap. Dan
November 1, 200619 yr had the same fault on my 2000 model. see if you get a good fat spark if not its likeley to be the CDI. its easy to change, see if you can borrow one or give lampkins a ring they are very helpful. lets us know how you get on. good luck.
November 8, 200619 yr Author Turns out it was a wiring problem. Previous owner who bought bike to play in a field had cocked up the wiring. Wish i had spotted it sooner!
November 8, 200619 yr Hi Chris, hope you didn't lay out much cash before you found the problem.. The one my dad bought just after me was screwed till the first time I went down the road (they live in the west of scotland) we stripped mine and he mirrored the wiring in it. Worked fine, then the cdi packed in!!! glad you got it going Donald
December 7, 200619 yr Author Thanks slapshot. I too had to change the cdi shortly afterwards. Not happy with the bike at the mo it takes forever to start and runs like a dog for ten minutes until it warms. dealer says I have piston slap
December 7, 200619 yr That's what happens as you get older With mine open the petrol tap, open the choke, snick it into gear rock it back and fore to check the clutch is free, then a good hard prod on the kickstart no throttle, first or second kick every time, leave choke on for 10 sec switch it off and warm it up gently. Lots of folks seem to have problems starting them. I think I've been really lucky with mine though not had any major problems that couldn't be sorted quickly. Cheers Slapshot
