November 2, 200620 yr please help me discover wats up with my bike i road it last sat for a couple of hours practice and it was running fine, then sunday morn i start it to warm up for a trial and it dies after a minit or so, i start it again and the same thing, and again, i change the plug and it still dies. (went home gutted) i think it my be water due to washing so i check the carb there is a little i flush out carb with petrol put back together start it and it dies, do you think it possible i have water in the petrol tank, or am i missing something else. your help and advice would be most greatfuly recieved
November 3, 200620 yr my sherco used to do it all the time, after weeksof trying to sort it i found out it was the original kill button so changed it for a yam style one and has never missed a beat since
November 3, 200620 yr I`d suggest giving the carby a good overhaul could be a little bit of dirt in a jet, check all rubbers are in good condition not split and all are correctly fitted as someone else mentioned clean filter and air box, check spark, if all still fails try discontecting the kill switch? if all that fails do this
November 3, 200620 yr Author thank you so much for your suggestions, i will investigate the kill button as i have illiminated all water from every were and put a new air filter in, so it must be that.........please bike god let it be that.
November 3, 200620 yr Author sorted, it was the kill button after all, im am so happy thanks for taking the time to help me, if we ever meet ill by u all a drink, thanks again guys
November 4, 200620 yr I was just going to suggest a blocked fuel cap breather hose, but the kill button it was then!!!
