Mini Bike With Oil Injection?
sam
I did a compression test by putting a little oil in the cylinder, the reading is the same, 90-100.
But, then I took off the exhaust and the compression test shows over 120-140lbs.
So. is this a sign that the exhaust is plugged?
Sam,
Have you tried starting it with the exhaust off?
Not sure if it would run correctly that way or not due to back pressure being wrong but that may help to figure out if exhaust is plugged.
I purchased a new piston and ring set for this bike, also in the set is a spring looking part that must go under the top ring, is this necessary on a freshly bored and honed cylinder.
I've actually put this mini-bike on the back burner to fiddle with a new sherco!
Runs perfect! New top end, eliminated oil injection, One super happy kid yesterday.
The largest problem was solved with a giant bonfire, there was so much sludge in the exhaust I tossed the little muffler in a giant fire, burnt that baby but good!
