kevhenson Posted March 1, 2007 Share Posted March 1, 2007 was just wondering which is the correct oil to put in the box on these as gas gas list 5w 30 but a lot of people seem to use atf fluid, so which is correct/ better and for what reasons? thanks Quote Link to comment Share on other sites More sharing options...
seandellear Posted March 1, 2007 Share Posted March 1, 2007 I would reccomend ATF Dexron 3! Ver nice fell to the lutch with no drag! Great! Quote Link to comment Share on other sites More sharing options...
kevhenson Posted March 1, 2007 Author Share Posted March 1, 2007 no drag sounds good to me, no adverse effects from using atf then Quote Link to comment Share on other sites More sharing options...
ritcrider Posted March 1, 2007 Share Posted March 1, 2007 Dexron 3 ATF in my Pro since 02...........works great and is very inexpensive at Autozone. Quote Link to comment Share on other sites More sharing options...
gdnhalley Posted March 1, 2007 Share Posted March 1, 2007 Esso unifarm works very well in an 02 280 txt, and in every other bike I have ever owned. Quote Link to comment Share on other sites More sharing options...
fetona Posted March 2, 2007 Share Posted March 2, 2007 no drag sounds good to me, no adverse effects from using atf then No, I've been using it in my 2001 TXT280 for a couple of years. Quote Link to comment Share on other sites More sharing options...
kevhenson Posted March 6, 2007 Author Share Posted March 6, 2007 put atf in it at the weekend and the clutch is completely different now.... sooo much better, im guessing the atf will need changing as often as i would normal oil? thanks all Quote Link to comment Share on other sites More sharing options...
seandellear Posted March 6, 2007 Share Posted March 6, 2007 It is so cheap to run it on I would change it every 3-4 trials! Kepp it lovely and fresh! Take it easy! Sean Quote Link to comment Share on other sites More sharing options...
