Scorpa Clutch
yamahaty250xox
hi everyone
my freind has just bought a scorpa 04 and the clutch wont come right into the bar.
its as if something is jamming but i cant see what.
also it at high revs.
im sure its something stupid but has anyone ever had this problem before?
thanks in advance :(
max
Has he checked the adjustment of the lever rod???? sounds like the piston is going all the way to the stop. if you back it out it will come back to the bar but will move the bite point.
Hi Max,
I just had the same thing on a friend's SY250.
In this case it was the slave cylinder adjustment being out too far, allowing the slave piston to end up fouling against the circlip at the end of the slave cylinder. At the same time, we cleaned out the end of the slave cylinder with brake clean, then lubed with hydraulic oil and now the clutch action is a lot easier and smoother.
Bye, PeterB.
