November 15, 200719 yr How the hell do you get the rear break pedal out ? I have removed the allen key bolt where the pedal pivots , the spring and plunger removed and then the pedal seems to be free . But can i hell as jiggle it out ! Is there a special technique ? Or is it a total dismemberment of the rear end ? Forgot to say that the pedal is very slightly bent and i do mean very slightly. All help greatly appreciated . Cheers Edited November 15, 200719 yr by Dougie Pumpkin
November 15, 200719 yr if i remember correctly, i removed the folding tip and it came out backwards, i also seen to remember having to get someone to sit on the bike to get the right heightto remove it ? sorry i was'nt on more use paul
November 15, 200719 yr Author if i remember correctly, i removed the folding tip and it came out backwards, i also seen to remember having to get someone to sit on the bike to get the right heightto remove it ?sorry i was'nt on more use paul I removed the toe tip as well, still o joy.. but will try getting the mrs to sit on it. Thanks
November 15, 200719 yr They do come out with a struggle, i done two on my 06, cant remember which way though sorry.
November 15, 200719 yr will try getting the mrs to sit on it. Thanks Never mind that, get back in the garage and sort the pedal out
November 15, 200719 yr QUOTE(Dougie Pumpkin @ Nov 15 2007, 03:12 PM) will try getting the mrs to sit on it. Thanks Never mind that, get back in the garage and sort the pedal out now THATS funny!
November 16, 200718 yr Author Never mind that, get back in the garage and sort the pedal out When i pressed the add reply button, i knew someone would say something, just dint have time to change it
September 27, 200818 yr Just pulled the rear brake pedal off my 2004 Rev 3. This is what I did. (1) Undo allen bold (2) Remove brake rod clip & detach rod from pedal (3) Remove chain spring slink & remove chain (4) Joggle the rear pedal up & back and remove threaded bush from rear of pedal (5) Pedal will not feed out forwards from frame Worked for me. I believe removal of swinging arm also works but sounds a bit more work. Good luck.
September 27, 200818 yr I found when we put weight on the bike it opens up the clearance for the lever and it slides out. Same going back in.
