yamahaty250xox Posted April 22, 2008 Share Posted April 22, 2008 hi all when i changed my plug earlier it was black with soot. im assuming that the bike is running rich but i have no idea how to sort it. sorry for being such a pain max Quote Link to comment Share on other sites More sharing options...
rdchair Posted May 14, 2008 Share Posted May 14, 2008 are you running the correct 80/1 oil mix? too much oil will dirty the plug Quote Link to comment Share on other sites More sharing options...
manwithtool Posted May 15, 2008 Share Posted May 15, 2008 make sure you have run the bike for a while before looking at the plug.....If you start it up on choke and the look at the plug it might well be black.....Also if the bike is running ok, and revving out cleanly, ticks over nicely, then leave it alone... And of course I agree with the previous post. Quote Link to comment Share on other sites More sharing options...
trialanderror Posted May 15, 2008 Share Posted May 15, 2008 hi, i asume that you have checked that the air filter is clean and that you are running a bp5es or 6 ?. check how many turns the air screw is out and wind it all the way in and back out 1 1/4 turns to start with . warm the bike up, if it seems to be running ok ride it up and down a few times so it clears the motor out i.e. give it a bit ,then while riding pull the clutch in and hit the kill switch so that the motor doesnt have time to idle. take plug out and check colour, a nice biscuit colour in the middle is ideal. if it is still black turn the air screw out another 1/8 of a turn at a time till you get that biscuit colour. hope this helps . Quote Link to comment Share on other sites More sharing options...
postmanpat Posted May 15, 2008 Share Posted May 15, 2008 Hi,question for Trialanderror,how many turns out on the airscrew?,i thought it was 3-4 turns? Quote Link to comment Share on other sites More sharing options...
tt5th Posted May 15, 2008 Share Posted May 15, 2008 Its 1 and a half at standard according to the manual I downloaded. Quote Link to comment Share on other sites More sharing options...
postmanpat Posted May 16, 2008 Share Posted May 16, 2008 I would check on the carb type-03s defo say 3-4 turns Quote Link to comment Share on other sites More sharing options...
rdchair Posted June 3, 2008 Share Posted June 3, 2008 Hi I was advised 3 and 3/4 for my 97 with an 03 carb ? Quote Link to comment Share on other sites More sharing options...
