April 26, 200818 yr The fan on my sy wont come on when bridged i put a new thermostat in the other day but it only worked for a while. how much will a new fan cost?
April 26, 200818 yr the fan is now working, why would it do this ? has it happend to you? trace all the wiring from the stator and see if its worn through somewhere, normally the fan either works or doesn't in my experience rather than intermittent.
April 26, 200818 yr Have you recently removed or altered the lighting circuit wiring? Edited April 26, 200818 yr by HAM2
April 26, 200818 yr Author i unplugged the front light, but this was just unpluged from the headstock. and none of the harnes was removed..
April 26, 200818 yr Under the seat is a black cylindrical unit with a pair of wires coming out. Check the connections and wires into it as the fan will not work without it. I had the wire to it melt on to the middle box. Sometimes the connector needs crimping up a bit.
April 27, 200818 yr Under the seat is a black cylindrical unit with a pair of wires coming out. Check the connections and wires into it as the fan will not work without it. I had the wire to it melt on to the middle box. Sometimes the connector needs crimping up a bit. Wot he said !
April 28, 200818 yr I noticed you had an earlyer topic about coating you frame ?? did you do this ? if so check the earth points they may need some coating removed ??
