angusgill Posted July 30, 2008 Share Posted July 30, 2008 its come to the last resort of drilling the clutch bolt head out/off, i have tried everything from tapping it around with a punch,torx, and snap on easy outs!! do i drill the head off, pull the clutch off then use a pair of mole grips on the threaded bit sticking out? Quote Link to comment Share on other sites More sharing options...
jse Posted July 30, 2008 Share Posted July 30, 2008 its come to the last resort of drilling the clutch bolt head out/off, i have tried everything from tapping it around with a punch,torx, and snap on easy outs!! do i drill the head off, pull the clutch off then use a pair of mole grips on the threaded bit sticking out? That might be the way to do it. That booger is down inside the shaft but you'll want to get the last piece out. Even though it seems welded in now, Murphy's Law dictates that it will loosen and drop into the clutch if left inside and the engine buttoned up. Jon Quote Link to comment Share on other sites More sharing options...
tt5th Posted July 30, 2008 Share Posted July 30, 2008 (edited) Thats the way I'd do it but be warned I went to the 'Hackit and Bodgem' school of mechanics! I'd be as careful as possible not to damage the clutch basket itself using as smaller drill bit as I could to get the job done and then make sure even after cleaning it before reassembly to do maybe 2 quick oil changes to ensure any filings are out. Edited July 30, 2008 by tt5th Quote Link to comment Share on other sites More sharing options...
stevec Posted July 31, 2008 Share Posted July 31, 2008 Is there anything left to try an impact driver ? Quote Link to comment Share on other sites More sharing options...
angusgill Posted July 31, 2008 Author Share Posted July 31, 2008 tried impact driver, gonna drill it 2nite, i have a extra long drill bit 5mm Quote Link to comment Share on other sites More sharing options...
