September 25, 200818 yr can anyone help took my carb apart 2 clean it now my bike wont run its flooding the engine i think its some think to do with the floats. please help don't know what else i can do.
September 25, 200818 yr The floats may simply be sticking, give the float bowl a few taps with your fingers and they may re-lease, if not drop the bowl off and make sure they are moving ok, it could also be **** on the fuel shutoff needle or its badly worn and letting fuel past. Edited September 25, 200818 yr by The Addict
September 25, 200818 yr Author yes tried them doth ways. the pin thats shuts of the fuel seems ok, but it seems to keep letting fuel in.
September 25, 200818 yr doesnt take much of a lump of dirt to let fuel pass the needle valve, I would take it off again,blow the passage through with an air line and clean the needle again.
September 26, 200818 yr They are fine, should be one of the solutions already mentioned. Only other thing I can think would be a sunken float!
September 26, 200818 yr Author just worked it out, the slide was up side down no wonder the bloke i got the bike off couldn't get on with it. i've been having trouble since i got the bike lets hope thats it. thanks 4 your help.
