October 16, 200818 yr Anyone tried the "Braking" sintered pads in a trials bike on here? lots of us having a few probs with the 4rt front brake in streams so need to try other pad makes or possibly another type of disc. Thanks Just
October 17, 200818 yr My impression is that discs are discs, unless you are talkind stainless, which requires a softer lining material to survive. Yet the sintered material may work well? Powdered iron on steel? May wear some disc? Price of performance in some cases, you never know!
October 17, 200818 yr How you doing addict ? Mont disc has bigger cutaways so try fitting a Gas Gas disc instead, this worked for a mate of mine. Best pads for performance I have found are DP (try shirty) but they damaged the discs on my scorpa. Goldfren pads are a good middle of the road option.
October 17, 200818 yr I've just tried my sons non floating gas gas front disc off his 50 cc ( same hub). Every gaser I've ridden has had better brakes than both the sherco's I've owned. Brakes now are heaps stronger with no squeal. The 09 sherco looks like it has the same discs as gas gas. Edited October 17, 200818 yr by clav3
October 17, 200818 yr Author Thanks guys, had heard about gasser discs being better than the Monts, got a set of sintered pads here and will stick them in next week and report back. Good thanks Glenn, bit older and uglyier though but really enjoying the 4rt
October 18, 200818 yr Author Me,Dad and Ralph sneaked up the dishes today for a few hours so I stuck the sintered pads in for a try. They work alot better than the Galfer ones,much stronger feel to the brake and you can lock it easy if you need to but not snatchy. Got a Trial up North tomorrow mainly streams so hope they work ok in the water - bone dry at the dishes so bloody good in the dusty stuff. Edited October 18, 200818 yr by The Addict
October 19, 200818 yr Author Rode the John Mac today with the new pads, plenty of water about and lots of wet muddy slippy stuff in the first group. Pads were 10 times better than before, never had any front brake problems all day,almost like riding in the dry they remained that strong. Will have a look at wear on the disc tomorrow and pads but to be honest they work so well I'm not bothered if it wears a disc out every 3 months its worth it.
October 21, 200818 yr I may be with you, noise problem alone on the Sherco may do it! Funny thing is the discs are from Braking! You would think the linings would work fine, where did you get them? As a sidenote, seems Sherco has changed discs on the '09, may be same as gassers, not sure?
October 21, 200818 yr Author Hi Mark, how you doing, I got the pads off Ebay UK, do a search for montesa 4rt and they will be on the first page, if you want a set sending let me know via pm Edited October 21, 200818 yr by The Addict
October 21, 200818 yr I'm using the dunlopad sintered pads on the 315R and have been very pleased with pad life, grip on the stainless disk was not as good on the rear as the and I cut a vertical grove to add grip, that worked fine, disk wear is no worry with the stainless disk, they do take a while to bed in
October 21, 200818 yr Author Motovintage, not checked the pads yet for wear after the weekend but really pleased with front brake now in the wet, still using the standard 4rt disc so will keep an eye on disc wear over the next few weeks. Back brake is fine on the 4rt so no need for a change there but may when the Galfers wear out.
October 22, 200818 yr Just, most of the UK companys do not ship to the US even if I could find them on ebay. I cannot recall if the Mont uses the same AJP caliper and pad as the Sherco or not? I think it does? I'll gladly cover the costs, post is not too much on light things, and I think you have the paypal, makes it easy. Let me know if you can confirm they are the same AJP workings, and I will give a go! MC
