High Startup Revs
betadad
Hi,
when starting the bike from cold (with choke), it starts first kick, but the revs shoot up, I have to immediately take the choke Off, and blip the throttle a couple of times and the revs slowly settle down. There are no mechanical linkage problems (throttle cable) the the carb is clean. Anyone out there help me?
Why would it be normal ?.....I'd say you have a fault.
At best i'd say you have a leak of air in the rubber boot between the carb and engine. Check it by spraying brake cleaner on the rubber and the joints when the bike is warmed up. Try moving the carb about a bit when do it to get any possible hole to open up. If you have a leak the revs will go up momentarily.
The only other fault i can think of is that you could have a starting jet or air jet fault/missing.
Ralphy
