November 5, 200818 yr hi ive just got a fantic of my mate ive images in the attached album. I would like to identify it,as in what model it is , and what colour scheme it should have . the bike has a disc brake front and drum rear break. i hope to restore it up and have some fun on it.. cheers http://s167.photobucket.com/albums/u150/inchman/ Edited November 6, 200818 yr by brim
November 6, 200817 yr If it has 6 studs fixing the head then it is a 1986/1987 301 with 249cc. If only 4 stads then either a 241 with212cc or a 201 with 156cc. The capacity is stamped on the top of the engine behind the folded in kickstart.
November 6, 200817 yr I think the 201 (156cc) has a conventional kickstart as well. From here it looks like either a 241 or 301, but yes, counting the studs and looking for the cc stamp will clear that up. I had a 241 a number of years back. I loved it. It spoilt the then ubiquitous Yamahas for me as I loved it's snappy power delivery. TYs seemed too soft for me after that. It was totally reliable although mine was a very early 241 and had a drum front brake, which was woeful. You also need to keep on top of the suspension linkages as they seemed to need a lot of looking after to prevent them seizing. Happy days though. Looks like you've got your work cut out there though! Graham
November 6, 200817 yr Author thanks for the info, i checked the stamped info behind the kickstart. FANTIC 403 and 249.4 cc thanks for the info, thanks again. i looked at the images on r2wtrials link and it looks like the 301 as you's suggested. cheers brim Edited November 6, 200817 yr by brim
