4t Reving It's Knackers Off
Rode a really muddy trial today, on the 10th section of the 1st lap, the revs started to increase rapidly. The cable wasn't nipped and it sounds like the slider is re-seating. any suggestions?
Cheers.
If the cable isn't pulled out and if the slide is hitting bottom, I'd look for an air leak.
Mine did that a couple of times.
Found it was the fact I didn't have a normal breather pipe on but one of those REP one way things.
As bike got hot & caused petrol in tank to expand it was forcing fuel into carb!
Use standard breather pipe & now OK
Sounds terrible Mate!!!! You should have bought a Montesa like i told you!!! It could be because the beast is pump your forearms up that much you didn't realise you were pulling the throttle on full tittle!!!!
Sound advice mate clean the carb, get a one way valve for the tank!! Failing that sell it and buy a 500 MAICO!!! Prob got less power than that monster!!
