diligaf Posted February 21, 2009 Share Posted February 21, 2009 I took delivery of an 07 280TXT Pro yesterday. Problem is despite being difficult to start ,every 3rd kick or so it kicks back ala XR 500. I know that the selector gear was replaced recently. Has anyone had a similar experience, is this usual??? Quote Link to comment Share on other sites More sharing options...
lowbrow Posted February 21, 2009 Share Posted February 21, 2009 Get it on compression, bring the kick start back to its start position then give it a good firm kick. You're being too gentle with it. Quote Link to comment Share on other sites More sharing options...
lee harris Posted February 21, 2009 Share Posted February 21, 2009 Get it on compression, bring the kick start back to its start position then give it a good firm kick. You're being too gentle with it. agreed Quote Link to comment Share on other sites More sharing options...
docheckle Posted February 21, 2009 Share Posted February 21, 2009 Ita all about technique, don't touch it up kick it as if your life depends on it. Lift your left leg off the floor and put all your weight on the kick starter in one smooth action. Quote Link to comment Share on other sites More sharing options...
sherco25016 Posted February 21, 2009 Share Posted February 21, 2009 i have a sherco that use to kick back ino its not the same, i started turning the petrol off when it was left in the shed josh Quote Link to comment Share on other sites More sharing options...
