Kickstart Spring Tiger Cub.
honda pants
Would this pic be any help HP
Vinnie :D
Vinne,
Thanks for the photo. The two holes above the clutch actuating arm what are these for? Surely they will allow water to get into the casing ( i have blocked mine off for now).
Regards. :D
Edited by honda pants
  • 4 weeks later...
The two hole are there for a reason.. the plain one is for the ignition wire from the points to feed through. The extended one is for the engine breather, which works from the cam. Its timed and blows into the outer case, and then out through the hole at the back. If you block them both you will have nowhere for the air pressure to go and oil will leak from everywhere..
Can you not put an extension on and take a tube up under the tank to get round this ?
