September 14, 200917 yr Hi, Forgive my ignorance, but how or can you turn down the tick over on my 4rt, it seems to be running too fast, only been out on it twice and to start with it struggled on tick over, i am presuming it was very tight, but ow it seems to be too fast... !st 4 bangere for me and I have not got a clue.. any help is much appreciated. thanks in advance Dougie
September 14, 200917 yr Been a while since I had one but I think there is a screw on the throttle body Cheers Jim
September 14, 200917 yr Dougie, The tickover is on the right hand side of the bike as you sit on it just under the mudguard infront of the airbox, its a large slotted screw cant miss it. Its important to have the revs high on the Mont I think 1800 rpm which seems way to high when you first get on one, they start easier with high revs and much less likely to stall whilst running loaded rpm in turns etc. If its getting away abit then gear it down so it feels slower to ride. Make sure you have some slack in the throttle as the Mont doesnt like starting with any signs of a whiff of throttle and let the bikes fan kick in before you touch the throttle at all from cold. If you got a standard air filter and flame guard swap it for the Jitsie filter so you can get rid of the flame guard. I usually wash the oil out of a new Jitsie filter and re oil with a small amount of PJ1 filter oil. The Mont doesnt like oily filters and the Jitsie has too much from new. A nine tooth front sprocket works really well on the 4rt, it has loads of gearing range even with a big sprocket change like that, I,ve been running 9/42/43 past two years on mine and it will still go up just about any hill in first. Have fun they are great bikes Edited September 14, 200917 yr by The Addict
September 14, 200917 yr Author Cheers mate, I will have a play tomorrow... Love the bike, just will take time getting used to it,,, it nearly caught me out the other day with a step... but hopefully I will gwt there.. once again thanks,.. regards Dougie
September 17, 200917 yr Author Any better with the bike Dougie? Not had time yet... too many fiddles going off... Will update you as soon as i have pal..
September 30, 200917 yr Author Thanks for that Addict.. Just got round to having a look.. My second question... Is there a cheap device that I can buy to accuratley measure the tick over RPM.. If so , what is it called, where from, how to use ???? Cheers Dougie
September 30, 200917 yr Yep, though cheap is a matter of opinion. Many inductive tachs, eg the draper and the ones sold at Maplin don't work on the Mont ignition cable I use a tiny tach www.tinytachuk.com , makes setting the tickover easy and if you leave it on the bike it records hours run - you can base your oil change regime on this if you wish
September 30, 200917 yr Author Yep, though cheap is a matter of opinion.Many inductive tachs, eg the draper and the ones sold at Maplin don't work on the Mont ignition cable I use a tiny tach www.tinytachuk.com , makes setting the tickover easy and if you leave it on the bike it records hours run - you can base your oil change regime on this if you wish Thanks for that... How much are they approx ? what about the pocket tiny tach, no connections required... how the hell does that work ....
September 30, 200917 yr The standard ones work by wrapping a thin wire 3-4 times around the HT lead, the pocket one will probably just have a clip or probe to put against the lead - they are just inductive tachs after all. Not sure how much they are, I bought the pro as it can be set for any motor, 2T or 4T plus it has a much faster refresh rate on the digital tach, think that was
