matt_urban Posted October 3, 2009 Share Posted October 3, 2009 my mates txt 320 is very hard to kick over is this normal ? it starts first kick but you really have to stand on it to turn it over . Quote Link to comment Share on other sites More sharing options...
lee harris Posted October 3, 2009 Share Posted October 3, 2009 (edited) yes the 320 and 321 motor have a flywheel as big as a small semi detatched house, yer gotta get that movin first ,-) Edited October 3, 2009 by Lee Harris Quote Link to comment Share on other sites More sharing options...
matt_urban Posted October 3, 2009 Author Share Posted October 3, 2009 any mods shave down the fly wheel ? loose a bit of tourqe but be able to start it between sections Quote Link to comment Share on other sites More sharing options...
laser1 Posted October 3, 2009 Share Posted October 3, 2009 These bikes have high compression and require good kicking technique. Make sure you get your weight above the bike - stand on the uphill side of the bike or find somthing to stand on to help improve your leverage. Use an Iridium plug gapped to 0.022-0.024" to get a better spark with low turnover rpm. Quote Link to comment Share on other sites More sharing options...
howie314 Posted October 3, 2009 Share Posted October 3, 2009 hi, i just put a new piston in my 250 and is very hard to kick over first time. What ido now is basically get to compression point then just lean a small amount of weight on kickstart for couple of seconds. this will reduce the compression a little, then give it a good kick and off you go. I am 14st and i can put 100% of body weight on kckstart and it dnot budge an inch. easiest way i have foundto get mine going with out putting too much pressure on kicker etc. if you search gasgas usa site there are videos showing starting techinques. cheers Quote Link to comment Share on other sites More sharing options...
gii Posted October 9, 2009 Share Posted October 9, 2009 I had three 320/321/330s and could start them all sitting down, I could also stand on the kickstart without it moving, it's just technique to get over the compression. Easiest way is to put the bike in gear, pull it backwards 'till the piston comes to up to compression, pull the clutch in and kick. that way you get around 330 Quote Link to comment Share on other sites More sharing options...
