October 7, 200917 yr Hi there! Can anyone please confirm how to fit a kill switch to Montesa 247 Cota. Is it just a case of connecting one of the wires to the lower terminal on the coil, i.e. the terminal with the blue wire attached, and the other wire to an earth on the frame or bars? This is what is stated in the Clymer manual for electronic type ignition but it doesn't mention how to fit switch for standard points type system. Jamieson
October 7, 200917 yr On a points system its much the same, the kill switch needs to basically short the LT to ground. Just like the points being closed. Wayne...
October 8, 200917 yr Author Thanks Wayne, I couldn't see why it would be any different, it just seemed a bit strange that the Clymer manual specifically makes reference to the electronic ignition and doesn't mention the standard points type. Simon
October 18, 200917 yr Hi While you are mucking around with the kill switch, why don't you change the position of your condenser? I always had bad problems with my points having to be filed and reset every couple of months as the current position under the flywheel could not be worse with heat etc etc. I actually put the condenser under the tank and since then the bike has been fine. I can't remember how I wired it up but it was very simple. If you are interested I can have a look and let you know. See ya
October 20, 200917 yr Author Yep, I would appreciate that.....you're not the first person that's mentioned condenser problems to me. Cheers! Simon
October 22, 200917 yr Hi mate, regarding the condenser Take the flywheel off and take condenser out from where it currently sits. Find somewhere suitable on the frame (my seats under the tank) and drill a small hole to attach and earth the condenser. The wire from the condenser is then joined to the black wire going to the coil and that is it. Your kill switch wire can also be joined to that black wire going to the coil. Hope that helps.
