grib Posted December 20, 2004 Share Posted December 20, 2004 What types of gear oil are people using in their Gas Gas Pros? I have recently bought a 2003 250 Pro which has 2004 clutch plates in it, I am using Silkolene light gear oil (10w40) and the clutch is dragging. I have bled the clutch but it doesn't seem to have made any difference. Quote Link to comment Share on other sites More sharing options...
grib Posted December 20, 2004 Author Share Posted December 20, 2004 (edited) Have just read Gasgasser's "Dragging clutch" post, I don't think I can get PJ1 Clutch tuner locally, does anyone know if it is it worth trying any others? Edited December 20, 2004 by Grib Quote Link to comment Share on other sites More sharing options...
luke Posted December 21, 2004 Share Posted December 21, 2004 (edited) I just use putoline GP10 racing, seems to work ok. They all drag i just get on with it. Edited December 21, 2004 by luke Quote Link to comment Share on other sites More sharing options...
perce Posted December 21, 2004 Share Posted December 21, 2004 I've used motul oil in all 4 Pros I've had. No clutch slip on any of them. Only problem I've ever had are a set of seals going when I left my 03 to stand for a month. Quote Link to comment Share on other sites More sharing options...
sparky-mark Posted December 21, 2004 Share Posted December 21, 2004 i've been using castrol dexron 3 atf recently and haven't had much bother with clutch drag. Quote Link to comment Share on other sites More sharing options...
pits300pro Posted December 21, 2004 Share Posted December 21, 2004 We use GM transfer case oil called Auto Trak 2. It seems to do the job just fine! Quote Link to comment Share on other sites More sharing options...
nickerlias Posted December 22, 2004 Share Posted December 22, 2004 I also have been using dexron 3 automatic transmission fluid and had no problems, can be cheap if you buy from the right place, ie not from Halfords! Must change regularly though, I change after every two or three rides. Quote Link to comment Share on other sites More sharing options...
jtt Posted December 23, 2004 Share Posted December 23, 2004 Scroll down the page to "Transmissions" CLICK HERE Quote Link to comment Share on other sites More sharing options...
grib Posted December 24, 2004 Author Share Posted December 24, 2004 When I spoke to Gas Gas UK they said don't use ATF with the 2004 clutch plates because it will make the clutch slip. Are you guys using ATF with the newer plates with no problems? Quote Link to comment Share on other sites More sharing options...
jtt Posted December 24, 2004 Share Posted December 24, 2004 I use ATF in my 2004 and it works perfect. For what it's worth, I've run ATF in all my bikes for years...including MXers (where the loads are MUCH greater). It's perfect for clutches as that's what its designed for. If you are concerned about slippage, use the "Type F" intended for older Ford type trannys. It is designed specifically to prevent slippage. Quote Link to comment Share on other sites More sharing options...
